소개
Utilisez ce tutoriel pour remplacer votre alimentation.
필요한 것
Retournez la PS3 et posez-la sur le dos.
Décollez soigneusement l'autocollant de garantie du boîtier inférieur pour accéder à un cache-vis.
Appuyez sur le mécanisme de verrouillage du connecteur d'entrée AC et tirez vers le haut pour le déconnecter de l'alimentation électrique.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
다른 61명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 11개
Hello, my question is I have an american ps3 which works on 110 volts and I'm in europe where they use 220volts so if I plug my ps3 without any converters will it burn or will it wor? Because I have a laptop and it works fine will my ps3 work like that aswell?
Perhaps, you should check the model of your PS3 and verify online. I have the CECH-2501B model (110v) but I use it in Nigeria (220v).
N3RVE -
Need help with console or trouble shooting the problem I am in the repair and purchased used or damage consoles even get it In way I can be able to talk to people who is looking for trouble shooting on phone or email or u to choose. But any console or device I am interested in buying it so I have it on hand I have seen people pay way more 4 the part. Wene it is sometimes. New or used Console r cheaper to get the whole different devices then part for the console
More to my comment I can be able to talk or text or email. SO you can do it yourself and it's not to bad to diy and your up to run the console after u fixed it. Do I you self. (Diy) even if people walk through it step 4 step.
