소개
Ce tutoriel vous explique comment remplacer la batterie de la PlayStation Vita.
필요한 것
Avec un tournevis cruciforme Phillips #00, dévissez les quatre vis 6,4 mm sur le boîtier arrière.
À l'aide d'une spatule, faites délicatement levier et retirez le dispositif de retenue du câble de batterie sur le boîtier arrière.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
다른 127명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 27개
Great guide. Only problem is this takes very steady hands (something i do not have)
chavis0704 - 답글
This is a great guide. It allowed me to execute the repair and do so without and damage. Just be careful with the triggers they can move and get caught while closing everything up.
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
