소개
Utilisez ce tutoriel pour remplacer la pile de la clé de la Honda Civic 2012-2016.
필요한 것
Posez la clé sur une surface, de telle sorte que le symbole Honda soit vers le haut.
Utilisez un tournevis cruciforme #0 pour dévisser l'unique vis.
Insérez l'extrémité plate de votre spatule (spudger) dans l'orifice situé sur le côté de la clé/télécommande.
Faites levier afin de séparer les deux moitiés de la clé.
Avant de retirer la pile usagée, notez bien quel côté est visible (+ ou -). Il faudra installer la nouvelle pile de la même manière.
Retirez la pile usagée.
Installez la bonne pile dans le même sens que l'originale.
Pour réassembler les pièces de la clé, suivez les instructions du tutoriel en sens inverse.
다른 18명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 26개
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Thanks, Harry!
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Thank you very helpful!!!
