소개
Démontez la vitre arrière pour accéder aux composants à l'intérieur de votre iPhone 4.
필요한 것
동영상 개요
Éteignez votre iPhone avant de commencer le démontage.
Sur le boîtier arrière de votre iPhone 4, il y a ou bien deux vis cruciformes #000 ou bien des vis Apple 5 points Pentalobe (deuxième image). Vérifiez de quelles vis il s'agit et assurez-vous d'avoir le tournevis qu'il vous faut pour les enlever.
Enlevez les deux vis de 3,6 mm (Pentalobe ou cruciforme #000) près du connecteur de dock.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
다른 806명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
첨부 문서
댓글 9개
The replacement part for the iPhone 4 rear panel has two thin, clear overlays on the inside surface--a larger one that runs the full length, and a small one that only covers the lens. These should be removed prior to installation. Also, the first rear panel replacement I got from iFixit was not an exact fit and would not easily "click" into place. They replaced it for free and the second one clicked right in.
rudisill49 - 답글
On step 3 when replacing the back panel with a new one, they aren't kidding about removing ALL the protective slips. There's THREE of them.
1), the obvious back slip that protects the new back.
2). the one inside the back protecting the side with the camera lens
3). the little square one OVER the lens itself.
First time I tried to reinstall my back, that tiny little square over the lens prohibited my ability to actually get the back on completely. My husband jammed it for me, but the screws still wouldn't take. It's amazing that these things are so precise that the tiny little film on the lens would make it that much tighter.
Anyways, hope that helps somebody. :)
Easiest repair I've ever done. Thanks y'all!
