주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
  1. MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement, Clutch Cover: 1 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement, Clutch Cover: 1 단계, 이미지 2/2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  2. MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement: 2 단계, 이미지 1/3 MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement: 2 단계, 이미지 2/3 MacBook Pro 13" Unibody Mid 2009 Clutch Cover Replacement: 2 단계, 이미지 3/3
    • Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 5,720
