소개
Mettez votre espace de stockage à jour avec un nouveau disque dur.
필요한 것
Sur le côté droit de l'iPod, insérez un médiator aussi loin que possible dans l'espace entre la partie avant en plastique et la coque arrière métallique.
Faites levier contre la partie avant en plastique avec le médiator pour déclipser les 5 pattes en plastique(voir photo 3).
Glissez l'outil le long du côté avec le même mouvement de levier pour détacher toutes les pattes.
Quand les 5 pattes du côté droit sont bien déclipsées, les deux parties du boîtier devraient s'écarter facilement.
Saisissez le disque dur d'une main et débranchez soigneusement la nappe orange du disque dur de l'autre.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
다른 133명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 16개
Just to let anyone wondering know: today I replaced the HDD with a 60 GB SSD - works like a charm. Maybe I can use this pod for another 8 years! :-)
Hi Stefan,
Iam very interested in replace my ipod photo HDD with a 60 GB SSD . What kind of SSD did you use?
Thank you
Luiz Bandeira
Brazil
I have a 4th generation iPod color 20GB. I tried to replace the hard drive with KingSpec 32GB SSD it didn't work it had formatting issues. I then did what most people do and bought a compact flash (CF) to 50 pin 1.8” IDE adapter. The adapter I bought came with a case the adapter's circuit board is red and has a master/slave switch on it. The case looks like a hard drive so the padding and bumpers on the Ipod's original hard drive can be reused with ease. Some people have had success with the KingSpec's SSD it is a nice option because it doesn't need an adapter. I have seen talk on the internet about iPod logic board versions and drive compatibility so maybe this is why the SSD didn't work for me. The key to converting to solid state is having a good adapter with the right brand and model of CF. I used a Kingston Ultimate 32GB CF it was indicated on Tarkan's website to be compatible with all iPods. Everything works perfectly now after installing the CF card with adapter.
