소개
Il n'y a rien de mieux que d'avoir trop d'espace de stockage et rien de plus frustrant que d'avoir un disque dur trop petit. Ce tutoriel va vous expliquer pas à pas comment remplacer le disque dur de votre Xbox 360 S.
도구
지정된 도구가 없습니다.
부품
Déplacez vers la gauche le loquet qui maintient en place le cache du disque dur.
Retirez le cache du disque dur de la console.
Attrapez fermement la languette en tissu étiquetée "250 GB" reliée au disque dur.
Tirez pour sortir le disque dur de la console.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
You will still have your saves and account if you replace your hard drive in the new xbox
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
Pour remontez votre appareil, suivez les instructions en sens inverse.
다른 94명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 3개
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
no the os is on the internal drive all the hard drive is doing is adding more storge space
My hardrive says its unformated but its not and i dont want to loose content
