소개
Avec le temps, la batterie à l'intérieur de votre aspirateur perd en charge et peut ne plus charger du tout. Cela peut être remédié grâce au remplacement du pack de batteries.
필요한 것
Enlevez les 6 vis extérieures 2mm Phillips #0 maintenant les deux parties blanches entre elles.
Pour réassembler l'appareil, suivez les instructions dans l'ordre inverse.
다른 31명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
QLX69님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 24개
Replace the ni-cad pack with a li-ion one. 4 each 18650 cells will give you 14.8vdc. If you use/buy a computer battery you’ll have enough cells for 2 repairs. Get the highest capacity cells you can, i.e. 2.6ahr or higher. Solder them all in series, charge it up and listen to it SCREEM. Works for me. (Reason for computer battery is the quality of the cells and they have tabs to solder to) mikey
There is a resistor there so the higher voltage will cause the resistor to melt. Did you receive your EE tech degree at an ITT school?
Whatever the componentry there is always a reasonable overvoltage margin. Mikes post should be fine.
