소개
Lorsqu’une tirette d'une fermeture éclair se casse ou que le curseur s’use, il n’est pas nécessaire de changer la fermeture éclair entière. Remplacez simplement le curseur et la butée qui l'empêche de glisser. C’est une réparation rapide, mais qui permettra d’utiliser à nouveau votre vêtement confortablement. Déterminez d’abord la taille du curseur en le retournant.
Pour les pièces de rechange ou une assistance supplémentaire, contactez Service clients Patagonia.
필요한 것
동영상 개요
Cherchez la butée du zip du côté où se trouve le curseur.
Coupez-la à l’aide de la pince coupante.
다른 59명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 23개
Off of another zipper
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
