주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair Guide for the LG Net10
필요한 것
  1. Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 1 단계, 이미지 2개 중 1개 Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 1 단계, 이미지 2개 중 2개
    • Frontal view and rear view of the LG Net10 prior to disassembling.
  2. Repair Guide for the LG Net10: 2 단계, 이미지 2개 중 1개 Repair Guide for the LG Net10: 2 단계, 이미지 2개 중 2개
    • Remove battery back cover by applying pressure along the groove. The LG logo should be up right. Apply the pressure downwards to remove the cover.
  3. Repair Guide for the LG Net10: 3 단계, 이미지 2개 중 1개 Repair Guide for the LG Net10: 3 단계, 이미지 2개 중 2개
    • Remove the battery from the top of the battery.
  4. Repair Guide for the LG Net10: 4 단계, 이미지 1개 중 1개
    • Remove the SIM card, by pushing down on the top of the SIM card and sliding it out from under the metal band.
  5. Repair Guide for the LG Net10: 5 단계, 이미지 2개 중 1개 Repair Guide for the LG Net10: 5 단계, 이미지 2개 중 2개
    • Remove all four screws from the back of the phone by using a small Phillips head screwdriver and turning it counterclockwise.
    • The screws are 0.5 centimeters.
  6. Repair Guide for the LG Net10: 6 단계, 이미지 3개 중 1개 Repair Guide for the LG Net10: 6 단계, 이미지 3개 중 2개 Repair Guide for the LG Net10: 6 단계, 이미지 3개 중 3개
    • Use a wedge, or flat edged tool to separate the phone. Make sure to circle around the entire phone, especially the corners to pull it apart. This can be difficult. This may take several tries, so make sure to be persistent.
  7. Repair Guide for the LG Net10: 7 단계, 이미지 1개 중 1개
    • Separate and remove the two hard covers and the keypad.
  8. Repair Guide for the LG Net10: 8 단계, 이미지 2개 중 1개 Repair Guide for the LG Net10: 8 단계, 이미지 2개 중 2개
    • Then remove the motherboard from the hard back of the phone.
  9. Repair Guide for the LG Net10: 9 단계, 이미지 1개 중 1개
    • Once the phone is completely dissembled, you can replace the screen if it is cracked. You can also replace the keypad if the buttons do not work or if there are other issues with the keypad. Another common desire people have is to unlock the phone. In order to do this, you must replace the SIM card, which is explained in the steps above.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gina
회원 가입일: 04/15/13
146 평판
안내서 2개를 작성함
SUNY Cortland, Team 1-1, Getto Spring 2013 SUNY Cortland, Team 1-1, Getto Spring 2013 회원
SUNYCORT-GETTO-S13S1G1
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 38
전체 시간: 1,495
