주요 콘텐츠로 건너뛰기
Repair Loose Floorboard Carpet in Vehicle
필요한 것
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: 1 단계, 이미지 1/2 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: 1 단계, 이미지 2/2
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
  2. Repair Loose Floorboard Carpet in Vehicle: 2 단계, 이미지 1/2 Repair Loose Floorboard Carpet in Vehicle: 2 단계, 이미지 2/2
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
  3. Repair Loose Floorboard Carpet in Vehicle: 3 단계, 이미지 1/1
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
  4. Repair Loose Floorboard Carpet in Vehicle: 4 단계, 이미지 1/2 Repair Loose Floorboard Carpet in Vehicle: 4 단계, 이미지 2/2
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
  5. Repair Loose Floorboard Carpet in Vehicle: 5 단계, 이미지 1/2 Repair Loose Floorboard Carpet in Vehicle: 5 단계, 이미지 2/2
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
  6. Repair Loose Floorboard Carpet in Vehicle: 6 단계, 이미지 1/1
    • Vacuum floorboard to remove any debris or dirt.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tedra Levatte
회원 가입일: 01/24/19
169 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 회원
USFSM-STEWART-S19S1G1
18 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 33
30일 전: 117
전체 시간: 6,239
