주요 콘텐츠로 건너뛰기
Repair Redragon S107 Unresponsive Keys
필요한 것
  1. Repair Redragon S107 Unresponsive Keys, Repair Redragon S107 Unresponsive Keys: 1 단계, 이미지 1개 중 1개
    • Unplug the USB cable to prevent issues during the repair.
  2. Repair Redragon S107 Unresponsive Keys: 2 단계, 이미지 2개 중 1개 Repair Redragon S107 Unresponsive Keys: 2 단계, 이미지 2개 중 2개
    • Remove all 13 Phillips screws located on the underside of the keyboard and gently remove the casing.
  3. Repair Redragon S107 Unresponsive Keys: 3 단계, 이미지 1개 중 1개
    • Lay the RGB LED panel flat on the desk.
    • Make sure that you do not damage the black wire on the left corner of the keyboard connected to the LED panel.
  4. Repair Redragon S107 Unresponsive Keys: 4 단계, 이미지 2개 중 1개 Repair Redragon S107 Unresponsive Keys: 4 단계, 이미지 2개 중 2개
    • Remove the three screws on the metal bracket located towards the top left on the keyboard.
    • Remove the rubber underneath the metal bar.
  5. Repair Redragon S107 Unresponsive Keys: 5 단계, 이미지 2개 중 1개 Repair Redragon S107 Unresponsive Keys: 5 단계, 이미지 2개 중 2개
    • Use a cotton swab and add isopropyl alcohol to thoroughly clean the green membrane sheet and place the green membrane back onto the key switches.
  6. Repair Redragon S107 Unresponsive Keys: 6 단계, 이미지 3개 중 1개 Repair Redragon S107 Unresponsive Keys: 6 단계, 이미지 3개 중 2개 Repair Redragon S107 Unresponsive Keys: 6 단계, 이미지 3개 중 3개
    • Use electrical tape to fix each contact strip that connects the green membrane to the motherboard into place.
    • Align the contact strips in place with the black lined traces provided on the motherboard.
  7. Repair Redragon S107 Unresponsive Keys: 7 단계, 이미지 3개 중 1개 Repair Redragon S107 Unresponsive Keys: 7 단계, 이미지 3개 중 2개 Repair Redragon S107 Unresponsive Keys: 7 단계, 이미지 3개 중 3개
    • Place the rubber and metal bar back into place. Reinstall the three screws tightly as this will ensure no complications with the alignment of contact strips.
  8. Repair Redragon S107 Unresponsive Keys: 8 단계, 이미지 2개 중 1개 Repair Redragon S107 Unresponsive Keys: 8 단계, 이미지 2개 중 2개
    • Place the RGB LED panel back onto the green membrane sheet. Reinstall the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Usman Khan
회원 가입일: 01/18/23
478 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 44
전체 시간: 1,280
