소개
The idler arm is an essential part of the steering and suspension system on a truck. This guide shows how to replace the most common broken part on an idler arm. Check this guide to learn how to take one off.
필요한 것
First the Idler arm must be removed from the truck. Another guide has instructions to take the arm off.
Using a 19 mm socket, take the nut off from inside the idler arm bracket.
If the arm rotates in the bracket, then it can be taken out of the vice and placed on the ground.
Once on the ground, your foot can be used to stop the arm from rotating and enable you to put torque on the nut.
Once the nut is off, the arm can be gently tapped out of the bracket.
