주요 콘텐츠로 건너뛰기
How to repair a frayed Apple AC Adapter Wire
필요한 것
  1. How to repair a frayed Apple AC Adapter Wire, How to repair a frayed Apple AC Adapter Wire: 1 단계, 이미지 1/3 How to repair a frayed Apple AC Adapter Wire, How to repair a frayed Apple AC Adapter Wire: 1 단계, 이미지 2/3 How to repair a frayed Apple AC Adapter Wire, How to repair a frayed Apple AC Adapter Wire: 1 단계, 이미지 3/3
    • Locate the damaged or exposed area on the adaptor wire.
    • Move the cable organizer clip away from the damaged or exposed area.
  2. How to repair a frayed Apple AC Adapter Wire: 2 단계, 이미지 1/2 How to repair a frayed Apple AC Adapter Wire: 2 단계, 이미지 2/2
    • Measure the approximate length of heat shrink needed to throughly cover all nearby damage with a single piece of heat shrink.
    • The length of the heat shrink should be longer than the actual length of the damaged or exposed wire.
    • Use 3/8"(10mm) diameter heat shrink. This size diameter is large enough to slide over the charging interface and small enough to secure itself on the wire when heated.
    • Cut the heat shrink to the appropriate length using scissors.
  3. How to repair a frayed Apple AC Adapter Wire: 3 단계, 이미지 1/2 How to repair a frayed Apple AC Adapter Wire: 3 단계, 이미지 2/2
    • Slide the heat shrink over the wire until it covers all of the damaged or exposed area.
  4. How to repair a frayed Apple AC Adapter Wire: 4 단계, 이미지 1/2 How to repair a frayed Apple AC Adapter Wire: 4 단계, 이미지 2/2
    • Use a heat gun or a lighter to apply heat to the heat shrink.
    • Continue until the heat shrink has shrunk and is tightly attached to the wire.
    • When heating, always keep the heat gun moving around the heat shrink. Do not apply heat to one location for too long. Overheating the heat shrink may cause further damage to the wire or wire coating underneath and may melt the heat shrink itself.
    • Optional: Apply multiple layers of heat shrink if you think the wire will be used in more demanding situations and want to ensure its protection and longevity.
  5. How to repair a frayed Apple AC Adapter Wire, Add an additional layer on the ends of the Mac Charger Wire's Diameter: 5 단계, 이미지 1/2 How to repair a frayed Apple AC Adapter Wire, Add an additional layer on the ends of the Mac Charger Wire's Diameter: 5 단계, 이미지 2/2
    • The 3/8"(10mm) Heat Shrink Tube has a minimum diameter after shrinking (0.19"/5mm) that is larger than the Mac Charger Wire's Diameter. So, to create a proper hold, we need to increase its diameter. Wrap it in an electric tape or something like the red wire covering shown in the picture, to increase its diameter before shrinking it.
    • There is also 4:1 Shrink Ratio Tubing where you might not need to do this, but 2:1 Shrink Ratio Tubing is typically easier to get if you don’t want to order online.
  6. How to repair a frayed Apple AC Adapter Wire: 6 단계, 이미지 1/3 How to repair a frayed Apple AC Adapter Wire: 6 단계, 이미지 2/3 How to repair a frayed Apple AC Adapter Wire: 6 단계, 이미지 3/3
    • Once the heat shrink has shrunk and cooled down, flex the wire in different directions to ensure the heat shrink is properly attached to the wire.
결론
Apple MagSafe Power Adapters typically range from $20-$79. By following this simple repair you can save money and continue using your power adaptor. People with similar wire coating issues and different power adaptors can hopefully find this repair guide helpful since the repair process is nearly identical.
다른 33명이 해당 안내서를 완성하였습니다.
Ryan Mostofi
회원 가입일: 04/09/15
1,043 평판
안내서 1개 작성함
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 회원
CPSU-GREEN-S15S28G6
4 회원들
안내서 10개 작성하였습니다
댓글 10개
Thanks! Wish I had seen this repair technique a long time ago... would have saved a lot of money on buying new power supplies and an expensive laptop repair when a cracked cable shorted out. Much appreciated!
Catherine Todd - 답글
This method fried my cable and it stopped working… Do not recommend anyone to try it. Now I have to buy a new one…
John Myr - 답글
Minimum sensitivity required. I think you missed the part where it reads…
“When heating, always keep the heat gun moving around the heat shrink. Do not apply heat to one location for too long. Overheating the heat shrink may cause further damage to the wire or wire coating underneath, and may melt the heat shrink itself.”
Albert Einstein -
I know this is from 2017, but I had a big laugh when I read John Myr’s post. Who in their right mind would even attempt to make a repair if you don’t know how to use a heat gun or even a cig lighter? Further don’t try a repair if you don’t understand how to shrink shrink tube! LOL LOL I would have paid money to see this guy burn through his cord! OMG, thanks for the big laugh!
Maxwell Smart -
where do i get the red stuff??
Sammy Danger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 31
30일 전: 114
전체 시간: 78,501
