주요 콘텐츠로 건너뛰기
Repairing Acer Aspire 5100 Display Screen
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Repairing Acer Aspire 5100 Display Screen, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Repairing Acer Aspire 5100 Display Screen, Display Screen: 2 단계, 이미지 1/1
    • Flip the laptop back over and open it.
  3. Repairing Acer Aspire 5100 Display Screen: 3 단계, 이미지 1/1
    • Pry out the 4 screw covers with a dental pick or other small pointed tool, and remove the screws located beneath them.
  4. Repairing Acer Aspire 5100 Display Screen: 4 단계, 이미지 1/2 Repairing Acer Aspire 5100 Display Screen: 4 단계, 이미지 2/2
    • Use a plastic spudger to carefully pry the front bezel off.
    • The bezel will tend to "snap" off little by little, as you work around it, don't be afraid to use a little force.
  5. Repairing Acer Aspire 5100 Display Screen: 5 단계, 이미지 1/1
    • Now remove the top cover by unscrewing the two Phillips #0 screws found at the bottom of the panel.
    • You are removing the cover behind the LCD, not the LCD screen. The two screws are the only thing holding it so carefully support it so it does not pull on and damage any cables.
  6. Repairing Acer Aspire 5100 Display Screen: 6 단계, 이미지 1/1
    • Unplug the display data cable attached to the back of the LCD.
    • Do not touch this area,it destroys the backlight!
  7. Repairing Acer Aspire 5100 Display Screen: 7 단계, 이미지 1/1
    • Finally, remove the LCD screen by unscrewing the six screws connecting the LCD panel to the side frame.
결론
다른 3명이 해당 안내서를 완성하였습니다.
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 4,154
