주요 콘텐츠로 건너뛰기
Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons
필요한 것
  1. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons, Opening the Device: 1 단계, 이미지 1/1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
    • Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
  2. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons: 5 단계, 이미지 1/1
    • Make sure all of the buttons are move-able.
    • Press buttons on circuit board while listening for a click.
    • If everything works on the inside, that might mean you need a new circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Roppolo
회원 가입일: 10/25/13
384 평판
안내서 3개 작성하였습니다
University of Maryland, Team 4-2, Vijaybhaskar Fall 2013 University of Maryland, Team 4-2, Vijaybhaskar Fall 2013 회원
UMD-VIJAYBHASKAR-F13S4G2
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 707
