주요 콘텐츠로 건너뛰기
Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons
필요한 것
  1. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons, Opening the Device: 1 단계, 이미지 1개 중 1개
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
    • Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
  2. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons: 5 단계, 이미지 1개 중 1개
    • Make sure all of the buttons are move-able.
    • Press buttons on circuit board while listening for a click.
    • If everything works on the inside, that might mean you need a new circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nicholas Roppolo
회원 가입일: 10/25/13
426 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 970
