주요 콘텐츠로 건너뛰기
Repairing Billion Router BiPAC 7404VNPX VOIP
필요한 것
  1. Repairing Billion Router BiPAC 7404VNPX VOIP, Repairing Billion Router BiPAC 7404VNPX VOIP: 1 단계, 이미지 1개 중 1개
    • Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
    • Remove the screws and turn the router back upright.
    • The top of the case should now lift off.
  2. Repairing Billion Router BiPAC 7404VNPX VOIP: 2 단계, 이미지 2개 중 1개 Repairing Billion Router BiPAC 7404VNPX VOIP: 2 단계, 이미지 2개 중 2개
    • The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
    • While I was checking the solder side of the board I noticed there was a bad solder joint on this cap. You cant see it at this resolution though.
    • While checking the state of the other caps on the board I noticed that this one 1000uF 10v was also showing signs of heat stress.
    • Both capacitors were replaced.
    • You can see the new caps in position on the right.
    • For the princely sum AU $1.20 in parts, 20 mins setting up, 5 mins to fix, 5 mins to put it all away I have saved myself aprox $200 for a new VOIP router :)
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mikejgrantham
회원 가입일: 05/29/12
146 평판
안내서 1개를 작성함
2가이드 댓글
Champion!
Thanks for this.
$1.30 in parts saved me going out buying a new VOIP adapter.
Nick Gustafsson - 답글
No worries, Glad it helped :)
mikejgrantham - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,781
