주요 콘텐츠로 건너뛰기
Repairing Black and Decker BL3000S Power Cord
필요한 것
  1. Repairing Black and Decker BL3000S Power Cord, Blender Base: 1 단계, 이미지 1/2 Repairing Black and Decker BL3000S Power Cord, Blender Base: 1 단계, 이미지 2/2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Repairing Black and Decker BL3000S Power Cord: 2 단계, 이미지 1/1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Repairing Black and Decker BL3000S Power Cord: 3 단계, 이미지 1/2 Repairing Black and Decker BL3000S Power Cord: 3 단계, 이미지 2/2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Repairing Black and Decker BL3000S Power Cord: 4 단계, 이미지 1/1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Repairing Black and Decker BL3000S Power Cord: 5 단계, 이미지 1/1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Repairing Black and Decker BL3000S Power Cord, Power Cord: 6 단계, 이미지 1/1
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
    • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
  7. Repairing Black and Decker BL3000S Power Cord: 7 단계, 이미지 1/1
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
결론
다른 4명이 해당 안내서를 완성하였습니다.
Elmer Pres Urbano
회원 가입일: 10/05/12
148 평판
안내서 1개 작성함
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 회원
CPSU-REGAN-F12S6G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 37
전체 시간: 3,893
