주요 콘텐츠로 건너뛰기
Repairing Buttons on Casio fx-300ES Calculator
필요한 것
  1. Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 1 단계, 이미지 1/2 Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 1 단계, 이미지 2/2
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: 2 단계, 이미지 1/2 Repairing Buttons on Casio fx-300ES Calculator: 2 단계, 이미지 2/2
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 1/3 Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 2/3 Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 3/3
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: 4 단계, 이미지 1/1
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 1/3 Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 2/3 Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 3/3
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 1/3 Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 2/3 Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 3/3
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 1/3 Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 2/3 Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 3/3
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: 8 단계, 이미지 1/1
    • Refer to this picture if any buttons get misplaced or fall out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Daniel Riedeman
회원 가입일: 04/09/15
219 평판
안내서 1개 작성함
Cal Poly, Team 28-2, Green Spring 2015 Cal Poly, Team 28-2, Green Spring 2015 회원
CPSU-GREEN-S15S28G2
4 회원들
안내서 2개 작성하였습니다
댓글 4개
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - 답글
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - 답글
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - 답글
I repaired my Casio fx-300w, a similar calculator with similar buttons. My mother, who gave it to me, spilled coffee once when using it in her office. I got rid of the sticky coffee gunk formed nearly 12 years ago.
Matthew Yang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 33
30일 전: 88
전체 시간: 24,822
