주요 콘텐츠로 건너뛰기
Repairing Buttons on Casio fx-300ES Calculator
필요한 것
  1. Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 1 단계, 이미지 2개 중 1개 Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 1 단계, 이미지 2개 중 2개
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: 2 단계, 이미지 2개 중 1개 Repairing Buttons on Casio fx-300ES Calculator: 2 단계, 이미지 2개 중 2개
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 3개 중 1개 Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 3개 중 2개 Repairing Buttons on Casio fx-300ES Calculator: 3 단계, 이미지 3개 중 3개
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: 4 단계, 이미지 1개 중 1개
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 3개 중 1개 Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 3개 중 2개 Repairing Buttons on Casio fx-300ES Calculator: 5 단계, 이미지 3개 중 3개
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 3개 중 1개 Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 3개 중 2개 Repairing Buttons on Casio fx-300ES Calculator: 6 단계, 이미지 3개 중 3개
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 3개 중 1개 Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 3개 중 2개 Repairing Buttons on Casio fx-300ES Calculator: 7 단계, 이미지 3개 중 3개
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: 8 단계, 이미지 1개 중 1개
    • Refer to this picture if any buttons get misplaced or fall out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel Riedeman
회원 가입일: 04/09/15
219 평판
안내서 1개를 작성함
Cal Poly, Team 28-2, Green Spring 2015 Cal Poly, Team 28-2, Green Spring 2015 회원
CPSU-GREEN-S15S28G2
4 회원들
안내서 2개를 작성함
5가이드 댓글
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - 답글
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - 답글
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - 답글
I repaired my Casio fx-300w, a similar calculator with similar buttons. My mother, who gave it to me, spilled coffee once when using it in her office. I got rid of the sticky coffee gunk formed nearly 12 years ago.
Matthew Yang - 답글
وقعت حاسبتي من نوع كازيو على الارض فلم تشتغل بالرغم من انها لم تنكسر وقد اشتريتها قبل شهرين من فضلكم ساعدوني ماذا افعل؟
abir abir - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 80
전체 시간: 26,089
