주요 콘텐츠로 건너뛰기
Repairing Canon Powershot Camera indicates low battery and shuts down
필요한 것
  1. Repairing Canon Powershot Camera indicates low battery and shuts down, Repairing Canon Powershot Camera indicates low battery and shuts down: 1 단계, 이미지 1개 중 1개
    • First you need to remove the back cover of the camera, so that you can access the motherboard. Here is how it looks like with the backcover removed (4 scew removed for a powershot A1200). At the top, you can see the main pins connecting the battery contact to the motheboard, but it is difficult to access them.
  2. Repairing Canon Powershot Camera indicates low battery and shuts down: 2 단계, 이미지 2개 중 1개 Repairing Canon Powershot Camera indicates low battery and shuts down: 2 단계, 이미지 2개 중 2개
    • Then, i remove the screen (2 screws), so that the motherboard and the connecting pins are easylly accessible.
    • In the second picture, you can see that near the pins, there is a "+" and a "-" sign. Here, by gently pressing them with a screwdriver, I noticed that one of them was completly loose. That is the reason of the problem.
    • Then, it is simple to fix it by soldering the loose connection.
    • The problems comes from the fact that the battery pins are directly solded to the motherboard, therefore the force exerted to maintain the good contact with the battery is applied to the soldering, which may eventually brake.
    • Next, remount every thing in back order. Pay attention to keep the screen clean (remove any fingerprints), and every thing should work fine...
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Philiipe
회원 가입일: 11/01/13
207 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 30,871
