주요 콘텐츠로 건너뛰기
Repairing Display
필요한 것
  1. Repairing Display, Display: 1 단계, 이미지 1개 중 1개
    • Remove the 6 outer screws on the underside of the laptop.
    • Open the battery compartment and remove the 7 visible screws.
    • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
    • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
    • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
    • Reassemble the laptop by following these steps in reverse.
    • The monitor should work when powered on again.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
duncan
회원 가입일: 06/28/12
247 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 21
전체 시간: 12,493
