주요 콘텐츠로 건너뛰기
소개
I will be teaching end users how to repair old shoe laces without having to buy new ones constantly. This easy guide will have shoelaces looking new within 15 minutes. Follow the simple five steps to improve your laces.
  1. Cut of the excess frayed shoelace.
    • Cut of the excess frayed shoelace.
  2. Slip the entire heat shrink tube over the frayed part of the lace. Make sure to clump the frayed part of the lace together when inserting the tubing. Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction. Remember not to go beyond the frayed part of the lace with tubing.
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around. Make sure to heat the heat shrink tube all the way around, heating the entire tube When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. Repeat these steps on all the other frayed shoelaces.
    • Repeat these steps on all the other frayed shoelaces.
결론
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
다른 12명이 해당 안내서를 완성하였습니다.
Anirudh Jain
회원 가입일: 2015년 04월 09일
557 평판
안내서 1개 작성함
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 회원
CPSU-GREEN-S15S28G6
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 70
전체 시간: 4,797
