필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The left panel of the case has thumbscrews that release the left side from the case.
Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
System supported RAM is 184-pin DIMM DDR PC3200
