주요 콘텐츠로 건너뛰기
Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip
필요한 것
  1. Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip, Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip: 1 단계, 이미지 1개 중 1개
    • Cut away the old (likely disintegrated) strip from the blade using a knife. Get a waterproof bandaid and cut 4 or 5 thin strips from the sticky part and layer them to make a new strip. Use the smooth-type bandage; not flexible fabric. Then sharpen by stropping on blue jeans. Voila! Shaves just like new. Blow dry after shaving to prevent rust.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
PartsIn
회원 가입일: 12/31/12
247 평판
안내서 1개를 작성함
댓글 4개
This is great! I'll have to try it. I'd love more information on how to sharpen the blades on blue jeans. How much stroking does it take to sharpen them? How do you tell when it's sharp enough?
Kyle Wiens - 답글
Hey it takes about 15 to 20 strokes each way ( up and down) to maintain it. And 150 to 200 each way to re sharpen it. And when you can take off most of the hair on your arm in one pass its sharp enough
chase morris -
Yeah, a guide on "stopping" a razor would be great!
Daniel Beardsley - 답글
Hi, I have a sterling silver razor handle with. Gillette blade housing. The housing is worn and does no longer supports the blade. Can I get a replacement top and switch it out with the broken one? Thanks Kevin
Kevin Locke - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 46
전체 시간: 11,804
