주요 콘텐츠로 건너뛰기
Repairing HP OfficeJet 3833 Paper Jam
필요한 것
  1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: 1 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: 1 단계, 이미지 2개 중 2개
    • Remove all paper from the printer.
  2. Repairing HP OfficeJet 3833 Paper Jam: 2 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 2 단계, 이미지 2개 중 2개
    • Check the input tray, located in the back of the printer, for any paper remains and remove them.
  3. Repairing HP OfficeJet 3833 Paper Jam: 3 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Check the input tray for any foreign objects.
    • You may need to hold down the input tray and shine a flashlight inside to have a better look.
    • Long tweezers are recommended to remove objects such as thumbnails and tacks.
  4. Repairing HP OfficeJet 3833 Paper Jam: 4 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 4 단계, 이미지 2개 중 2개
    • Check the output tray, located in the front of the printer, for paper remains and remove them.
  5. Repairing HP OfficeJet 3833 Paper Jam: 5 단계, 이미지 3개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 5 단계, 이미지 3개 중 2개 Repairing HP OfficeJet 3833 Paper Jam: 5 단계, 이미지 3개 중 3개
    • Shut down the printer.
    • Hold down the power button until a message appears.
    • Select the Shut Down option.
    • A message will appear and the printer will turn off.
  6. Repairing HP OfficeJet 3833 Paper Jam: 6 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 6 단계, 이미지 2개 중 2개
    • Unplug the printer power cable from the wall outlet.
    • Remove the power cable from the back of the printer.
  7. Repairing HP OfficeJet 3833 Paper Jam: 7 단계, 이미지 3개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 7 단계, 이미지 3개 중 2개 Repairing HP OfficeJet 3833 Paper Jam: 7 단계, 이미지 3개 중 3개
    • Pull back on the front sides of the printer to remove the front panel.
    • Then pull the handle inside to remove the ink cartridge panel.
  8. Repairing HP OfficeJet 3833 Paper Jam: 8 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 8 단계, 이미지 2개 중 2개
    • Slide the ink cartridge to the side.
    • This step must be done carefully to prevent damage to the printer.
  9. Repairing HP OfficeJet 3833 Paper Jam: 9 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 9 단계, 이미지 2개 중 2개
    • Search for and remove any debris.
  10. Repairing HP OfficeJet 3833 Paper Jam: 10 단계, 이미지 1개 중 1개
    • Put the printer on its side.
    • You may need to open the top half and lay it down to prevent the printer from falling.
  11. Repairing HP OfficeJet 3833 Paper Jam: 11 단계, 이미지 2개 중 1개 Repairing HP OfficeJet 3833 Paper Jam: 11 단계, 이미지 2개 중 2개
    • Locate the cleanout door on the bottom half of the printer.
    • Open the cleanout door to remove unwanted debris.
결승점
작성자
3다른 기여자 명과 함께
Ivory S. Mayorga
회원 가입일: 09/16/20
193 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 67
전체 시간: 4,023
