위험
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
위험
소개
This is a cut and paste from a post by dodo105, available on the following web site : http://www.fixyourownprinter.com/forums/....
I did this fix and it works fine ! This is a pure example of how manufacturers implement planned obsolescence in their products. Capacitors are widely used in order to make a device fail after a given amount of time, due to their limited lifetime.
  1. Before attempting this repair, try the hard reset options found in this thread.
    • Before attempting this repair, try the hard reset options found in this thread.
    • Exercise extreme care in dealing with the capacitors as they can store quite a bit off power. Be very careful not to touch the capacitor leads or any exposed solder joints.
    • It is recommended to construct a capacitor discharge tool and only use well-insulated tools.
    • The 4 capacitors to change
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Antoine
회원 가입일: 2012년 06월 02일
137 평판
안내서 1개 작성함
Thanks! That was it!
In order to reach the board you only need to remove a total of 3 black torx screws:
- back plastic panel near power input
- ground trimming on the right of paper tray
- top of the memory card slots frame
remove gently the 3 plastic pieces starting from the ground-trimming, then to the memory card frame and finally the big plastic panel that covers most of the right side of the printer.
That last panel exposes 4 silver torx screws that hold the PCB in place.
Remove those 4 screws and unplug all connectors (there's a bunch of those..)
Since I only had a spare capacitor in my inventory I just replaced the first 330uF that seemed the most "damaged". By damaged I mean with the top of the capacitor more swollen.
That single capacitor was enough. The printer turned on and is now fully configured after an hard reset.
Thank you very much for the useful information!
pedroduarte - 답글
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 30
전체 시간: 5,843
