주요 콘텐츠로 건너뛰기
Repairing HTC Droid Incredible Optical Track Pad
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Repairing HTC Droid Incredible Optical Track Pad, Battery: 1 단계, 이미지 1/3 Repairing HTC Droid Incredible Optical Track Pad, Battery: 1 단계, 이미지 2/3 Repairing HTC Droid Incredible Optical Track Pad, Battery: 1 단계, 이미지 3/3
    • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  2. Repairing HTC Droid Incredible Optical Track Pad: 2 단계, 이미지 1/2 Repairing HTC Droid Incredible Optical Track Pad: 2 단계, 이미지 2/2
    • Remove battery, prying from the provided gap at the upper-right corner of the battery
  3. Repairing HTC Droid Incredible Optical Track Pad, Back Panel: 3 단계, 이미지 1/2 Repairing HTC Droid Incredible Optical Track Pad, Back Panel: 3 단계, 이미지 2/2
    • Depress MicroSD to eject it from the side of the case.
  4. Repairing HTC Droid Incredible Optical Track Pad: 4 단계, 이미지 1/3 Repairing HTC Droid Incredible Optical Track Pad: 4 단계, 이미지 2/3 Repairing HTC Droid Incredible Optical Track Pad: 4 단계, 이미지 3/3
    • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  5. Repairing HTC Droid Incredible Optical Track Pad: 5 단계, 이미지 1/3 Repairing HTC Droid Incredible Optical Track Pad: 5 단계, 이미지 2/3 Repairing HTC Droid Incredible Optical Track Pad: 5 단계, 이미지 3/3
    • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
    • Start at the top, and work clockwise, being careful not to break the clips.
    • There are, 1, 3, 2, and 3 clips on each side, respectively.
    • After the clips are disengaged, there are no cables holding the back panel in place.
  6. Repairing HTC Droid Incredible Optical Track Pad, Optical Track Pad: 6 단계, 이미지 1/3 Repairing HTC Droid Incredible Optical Track Pad, Optical Track Pad: 6 단계, 이미지 2/3 Repairing HTC Droid Incredible Optical Track Pad, Optical Track Pad: 6 단계, 이미지 3/3
    • Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
    • Remove Optical Track Pad from logic board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mobile Rapid Response Unit
회원 가입일: 05/07/12
1,941 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 960
