주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. First remove the rear case/battery cover
    • First remove the rear case/battery cover
  2. Remove the battery.
    • Remove the battery.
    • Remove the two T5 Torx screws.
    • Prise off the lower casing towards the right in the picture, taking care not to break the two tabs
  3. Remove the two further T5 torx screws
    • Remove the two further T5 torx screws
    • Remove the three Phillips #00 screws.
  4. Now carefully prise off the case all round and it will detach completely
    • Now carefully prise off the case all round and it will detach completely
  5. Prise up this connector
    • Prise up this connector
  6. And this one
    • And this one
  7. Lift up the retainer using a plastic opening tool.
    • Lift up the retainer using a plastic opening tool.
  8. And carefully pull out the tab connector.
    • And carefully pull out the tab connector.
    • NOW PAUSE WITHOUT MOVING ANYTHING!
  9. NOTE THIS FLEXIBLE RIBBON
    • NOTE THIS FLEXIBLE RIBBON
  10. Carefully lift up the board from the left-hand side allowing it to 'hinge' on the metallic ribbon connector you have just noted and allow it to lay flat
    • Carefully lift up the board from the left-hand side allowing it to 'hinge' on the metallic ribbon connector you have just noted and allow it to lay flat
  11. The freed connector for the screen should have unfolded
    • The freed connector for the screen should have unfolded
    • Now the screen can be pried from the outer case, but take care as you do so not to tear the metallic ribbon between the two casings
  12. To detach the screen it can help to  use a pry tool to push the screen from behind through the slot
    • To detach the screen it can help to use a pry tool to push the screen from behind through the slot
  13. The screen is detached and the connector can be wiggled out through the slot
    • The screen is detached and the connector can be wiggled out through the slot
  14. Remove the old screen and connector altogether
    • Remove the old screen and connector altogether
  15. The connector for the new screen now has to be wiggled back through the slot
    • The connector for the new screen now has to be wiggled back through the slot
  16. Once the connecter is pushed through the slot, you should now stick the new screen into place using suitable adhesive strip
    • Once the connecter is pushed through the slot, you should now stick the new screen into place using suitable adhesive strip
  17. Fold down the ribbon connector from the screen and carefully fold the two casing halves together again, making sure that the two connectors are sticking out of the side
    • Fold down the ribbon connector from the screen and carefully fold the two casing halves together again, making sure that the two connectors are sticking out of the side
  18. Reconnect the two connectors on the right hand side by pressing down
    • Reconnect the two connectors on the right hand side by pressing down
  19. Reinsert the ribbon connector on the left hand side and push down the retaining catch
    • Reinsert the ribbon connector on the left hand side and push down the retaining catch
  20. Clip the rear casing back on to the body
    • Clip the rear casing back on to the body
  21. Put the bottom cover back in place and then replace all the screws
    • Put the bottom cover back in place and then replace all the screws
  22. Replace battery and battery cover and all should now be well!
    • Replace battery and battery cover and all should now be well!
결론
다른 8명이 해당 안내서를 완성하였습니다.
Mikey Willbiscuit
회원 가입일: 2013년 05월 13일
507 평판
안내서 1개 작성함
Nice detailing of the teardown steps but the phone shown here is a regular HTC Wildfire (HTC G8) and not the latter HTC Wildfire S (HTC G13). Apparently, the orignal Wildfire has two variants (A3333 and A310e). Each variant uses a different digitizer (the touch glass panel on top of the actual LCD). If you need to buy a replacement digitizer, verify if your variant has an IC on the digitizer ribbon cable or not. On my phone, the shattered original digitizer had no IC on the ribbon and when I replaced it with one that had one, the phone wouldn’t recognize the touch inpupts.
Jeremy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 11,702
