주요 콘텐츠로 건너뛰기
Repairing Hungry Cat Savings Bank Gear
필요한 것
  1. Repairing Hungry Cat Savings Bank Gear, Repairing Hungry Cat Savings Bank Gear: 1 단계, 이미지 1/1
    • Turn the Hungry Cat Savings Bank off.
    • Using a coin, remove the cap covering the change storage.
    • Use a standard Phillips screwdriver #0 to remove the screw holding the battery cover in place.
  2. Repairing Hungry Cat Savings Bank Gear: 2 단계, 이미지 1/1
    • Empty all change from the Hungry Cat Savings Bank, or it will drive you bonkers during repair.
  3. Repairing Hungry Cat Savings Bank Gear: 3 단계, 이미지 1/1
    • Remove the battery cover and batteries.
  4. Repairing Hungry Cat Savings Bank Gear: 4 단계, 이미지 1/1
    • Remove the four screws holding the cover in place. You'll need a traditional Phillips screwdriver, not a screwdriver set, to reach fully into the wells.
  5. Repairing Hungry Cat Savings Bank Gear: 5 단계, 이미지 1/1
    • Turn over savings bank and slide case up. You might need to grab the base to pull it apart.
  6. Repairing Hungry Cat Savings Bank Gear: 6 단계, 이미지 1/1
    • Locate the jam. You might need to temporarily put in the batteries to activate the arm, so you can find the jam.
  7. Repairing Hungry Cat Savings Bank Gear: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the coin using a set of tweezers.
    • Reassemble the device and enjoy your working Hungry Cat Savings Bank!
결론
To reassemble your device, follow these instructions in reverse order. Make sure to remove the batteries before reassembling.
다른 6명이 해당 안내서를 완성하였습니다.
Jeannie Crowley
회원 가입일: 07/14/15
459 평판
안내서 2개 작성하였습니다
Ethical Culture Fieldston School Ethical Culture Fieldston School 회원
Business
3 회원들
안내서 2개 작성하였습니다
댓글 6개
Hi, my motor burned out, where could I get a replacement?
Krill - 답글
My one will not stop once it has grabbed a coin , the paw keeps coming out and it has to be turned off at the switch. And he doesn't meow anymore.
michael.tulley - 답글
I don’t have my box in front of me, but it sounds like the tray isn’t returning to the rest position fully. When you disassemble it, is there anything preventing the tray (where you put the quarter) from smoothly returning to rest position?
Jeannie Crowley -
How to you repair the Godzilla bank? Bought one yesterday and it completely stopped working?
divineangel1952 - 답글
Is there any sound at all coming from the bank or is it completely silent when you press the button?
Jeannie Crowley -
hi, hopefully someone reads this, but i just got this godzilla one, its brand new and i just put in batteries in it and placed the coin, it lit up and made noises but then it stopped completely and now its just stuck peaking out :(
Alexandra Rivera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 68
전체 시간: 5,880
