소개
Fix a blank car stereo face plate.
  1. Sorry for not including a complete tear down but I have no other images of this work.
    • Sorry for not including a complete tear down but I have no other images of this work.
    • Due to temperature changes in the car the solder will crack on this model and possibly others close to it causing the faceplate to no longer display. After unscrewing the housing and removing the cd unit locate the 10 surface mount resistors marked r27 shown in red.
    • Using a small tip soldering iron reflow the solder on each edge of the resistor. You should not need to add any extra but in my case I did for a few.
    • After all 20 contacts have been reflowed to the 10 resistors reattach the cd drive and case.
    • Enjoy your display like it was new again!
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
결론
다른 2명이 해당 안내서를 완성하였습니다.
ej e
회원 가입일: 2014년 02월 21일
177 평판
안내서 1개 작성함
quick note: most of these connect to eachother via the PCB, so the close together ones can be soldered directly together for ease. I succeeded in fixing my stereo's faceplate!
jbudorg - 답글
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 48
전체 시간: 4,274
