주요 콘텐츠로 건너뛰기
Repairing Lenovo R61i fan assembly replacement or cleaning
필요한 것
  1. Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 1 단계, 이미지 1/3 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 1 단계, 이미지 2/3 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: 1 단계, 이미지 3/3
    • identify the exact type of your ThinkPad
    • get the right fan assembly, in this case FRU P/N: 42W2779
    • disconnect power-supply
    • detach battery
  2. Repairing Lenovo R61i fan assembly replacement or cleaning: 2 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 2 단계, 이미지 2/2
    • find all five screws with the shown symbols and unscrew them
  3. Repairing Lenovo R61i fan assembly replacement or cleaning: 3 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 3 단계, 이미지 2/2
    • unscrew all the shown screws
    • These ones are tiny
    • watch the sizes of the screws
  4. Repairing Lenovo R61i fan assembly replacement or cleaning: 4 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 4 단계, 이미지 2/2
    • remove the palm rest carefully
    • If you have a touchpad or fingerprint reader watch the cables
    • blow the dust away
  5. Repairing Lenovo R61i fan assembly replacement or cleaning: 5 단계, 이미지 1/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 5 단계, 이미지 2/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 5 단계, 이미지 3/3
    • lift the keyboard carefully
    • watch the cable
    • Use a spudger to detach the cable
    • lift the keyboad and leave it on the side
  6. Repairing Lenovo R61i fan assembly replacement or cleaning: 6 단계, 이미지 1/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 6 단계, 이미지 2/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 6 단계, 이미지 3/3
    • just for reference: images showing the keyboard-connector
  7. Repairing Lenovo R61i fan assembly replacement or cleaning: 7 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 7 단계, 이미지 2/2
    • unscrew the left and right screw of the keyboard bezel and speakers
  8. Repairing Lenovo R61i fan assembly replacement or cleaning: 8 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 8 단계, 이미지 2/2
    • unscrew the first two screws of the shielding
  9. Repairing Lenovo R61i fan assembly replacement or cleaning: 9 단계, 이미지 1/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 9 단계, 이미지 2/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 9 단계, 이미지 3/3
    • carefully lift the wireless antenna cable from the cable guide
    • unscrew the last two screws from the keyboard bezel
  10. Repairing Lenovo R61i fan assembly replacement or cleaning: 10 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 10 단계, 이미지 2/2
    • watch the claws of the bezel (Sorry, no image!)
    • carefully pull out the keyboard bezel
    • flip the bezel 180°
    • watch the cables
  11. Repairing Lenovo R61i fan assembly replacement or cleaning: 11 단계, 이미지 1/1
    • remove the wireless antenna cable from the cable guide of the fan assembly
    • you might want to use a metal spudger to widen the cable guide if necessary
  12. Repairing Lenovo R61i fan assembly replacement or cleaning: 12 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 12 단계, 이미지 2/2
    • unscrew the fist, tiny screw of the clip
    • unscrew the longer screw of the clip
    • remove the clip
  13. Repairing Lenovo R61i fan assembly replacement or cleaning: 13 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 13 단계, 이미지 2/2
    • remove the shorter screw of the second clip
    • remove the longer screw of the second clip
    • remove the clip
  14. Repairing Lenovo R61i fan assembly replacement or cleaning: 14 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 14 단계, 이미지 2/2
    • remove the last two screws of the fan assembly
    • detach the power cord with a spudger
  15. Repairing Lenovo R61i fan assembly replacement or cleaning: 15 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 15 단계, 이미지 2/2
    • CPU with thermal grease
    • other chip with termal grease
    • carfully lift the fan assembly
    • you may need to pull a little more because of the thermal grease
  16. Repairing Lenovo R61i fan assembly replacement or cleaning: 16 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 16 단계, 이미지 2/2
    • take a spudger and remove the old thermal grease
  17. Repairing Lenovo R61i fan assembly replacement or cleaning: 17 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 17 단계, 이미지 2/2
    • get a paper-wiper
    • wrap the wiper around the spudger
  18. Repairing Lenovo R61i fan assembly replacement or cleaning: 18 단계, 이미지 1/2 Repairing Lenovo R61i fan assembly replacement or cleaning: 18 단계, 이미지 2/2
    • get some alcohol on the wiper
    • clean the CPU with the wiper
    • clean the chip with the wiper
    • Ensure there is no old thermal grease left
    • Follow this guide to add new thermal paste to the CPU.
  19. Repairing Lenovo R61i fan assembly replacement or cleaning: 19 단계, 이미지 1/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 19 단계, 이미지 2/3 Repairing Lenovo R61i fan assembly replacement or cleaning: 19 단계, 이미지 3/3
    • now place the new fan assembly
    • pay attention to the thermal grease on the backside of your new fan assembly
    • press down the CPU- and chip-connector
    • don't forget to plugin the power cable of the fan assembly
결론
다른 6명이 해당 안내서를 완성하였습니다.
Dennis
회원 가입일: 01/06/13
311 평판
안내서 1개 작성함
댓글 2개
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
tech4eleven - 답글
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
Ioannis Kolaxis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 29
전체 시간: 19,270
