주요 콘텐츠로 건너뛰기
Repairing Minolta Dimage Xt Lens Cover
필요한 것
  1. Repairing Minolta Dimage Xt Lens Cover, Casing: 1 단계, 이미지 3개 중 1개 Repairing Minolta Dimage Xt Lens Cover, Casing: 1 단계, 이미지 3개 중 2개 Repairing Minolta Dimage Xt Lens Cover, Casing: 1 단계, 이미지 3개 중 3개
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Repairing Minolta Dimage Xt Lens Cover: 2 단계, 이미지 3개 중 1개 Repairing Minolta Dimage Xt Lens Cover: 2 단계, 이미지 3개 중 2개 Repairing Minolta Dimage Xt Lens Cover: 2 단계, 이미지 3개 중 3개
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: 3 단계, 이미지 1개 중 1개
    • Place the internal electronics face-up. Look at the side with the flash turned towards you.
    • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
    • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
  4. Repairing Minolta Dimage Xt Lens Cover: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
    • Inside the yellow circle, the arm is in the correct position.
결론
Reassemble the casing by reversing steps 1 and 2.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Megan Milam
회원 가입일: 03/11/13
56 평판
안내서 5개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
1가이드 댓글
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 1,339
