이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
Open the bottom with a strong screwdriver. Be careful not to break the clips inside
Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic three times. At last switch must be pressed in.
다른 30명이 해당 안내서를 완성하였습니다.
댓글 44개
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
Yes, it's a miracle. :-)
VauWeh -
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao -
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
