주요 콘텐츠로 건너뛰기
Repairing Nintendo DS Lite Volume Switch
필요한 것
  1. Repairing Nintendo DS Lite Volume Switch, Battery: 1 단계, 이미지 2개 중 1개 Repairing Nintendo DS Lite Volume Switch, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Repairing Nintendo DS Lite Volume Switch: 2 단계, 이미지 1개 중 1개
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Repairing Nintendo DS Lite Volume Switch, Lower Case: 3 단계, 이미지 2개 중 1개 Repairing Nintendo DS Lite Volume Switch, Lower Case: 3 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Repairing Nintendo DS Lite Volume Switch: 4 단계, 이미지 1개 중 1개
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-point screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-point screws
  5. Repairing Nintendo DS Lite Volume Switch: 5 단계, 이미지 3개 중 1개 Repairing Nintendo DS Lite Volume Switch: 5 단계, 이미지 3개 중 2개 Repairing Nintendo DS Lite Volume Switch: 5 단계, 이미지 3개 중 3개
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Repairing Nintendo DS Lite Volume Switch: 6 단계, 이미지 1개 중 1개
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Repairing Nintendo DS Lite Volume Switch, Volume Switch: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Carefully use a pair of tweezers to remove the volume switch.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Philip
회원 가입일: 01/20/10
597 평판
안내서 2개를 작성함
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 회원
CPSU-MANESS-W10S16G30
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 100
전체 시간: 12,230
