주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Needed remedies:
- Screwdrivers
- Brush
- Oil
  1. Remove battery
    • Remove battery
    • Turn Netbook upside down
    • Unscrew all screws from the back of the pc
    • Remove the back plate
    • Unscrew metal cover on top of fan
  2. Gently lift the fan making sure not to drop dust into the motor of the fan below Clean fan blades Clean the fan house
    • Gently lift the fan making sure not to drop dust into the motor of the fan below
    • Clean fan blades
    • Clean the fan house
    • place the fan upside down so the metal pin points upwards
  3. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Apply oil
    • Apply oil
    • Apply one or two droplets of oil onto the metal pin
    • Place it on the motor and make sure it rotates without problems
    • In case there is still sounds coming from the fan when turned on, redo the cleaning and lubrication.
    • Assemble everything and test
결론
다른 9명이 해당 안내서를 완성하였습니다.
Knud
회원 가입일: 2012년 04월 17일
377 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,151
