주요 콘텐츠로 건너뛰기
Repairing Nokia 6500 Slide LCD
필요한 것
  1. Repairing Nokia 6500 Slide LCD, LCD: 1 단계, 이미지 1/3 Repairing Nokia 6500 Slide LCD, LCD: 1 단계, 이미지 2/3 Repairing Nokia 6500 Slide LCD, LCD: 1 단계, 이미지 3/3
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: 2 단계, 이미지 1/1
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: 3 단계, 이미지 1/3 Repairing Nokia 6500 Slide LCD: 3 단계, 이미지 2/3 Repairing Nokia 6500 Slide LCD: 3 단계, 이미지 3/3
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: 4 단계, 이미지 1/2 Repairing Nokia 6500 Slide LCD: 4 단계, 이미지 2/2
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: 5 단계, 이미지 1/1
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: 6 단계, 이미지 1/2 Repairing Nokia 6500 Slide LCD: 6 단계, 이미지 2/2
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: 7 단계, 이미지 1/2 Repairing Nokia 6500 Slide LCD: 7 단계, 이미지 2/2
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: 8 단계, 이미지 1/3 Repairing Nokia 6500 Slide LCD: 8 단계, 이미지 2/3 Repairing Nokia 6500 Slide LCD: 8 단계, 이미지 3/3
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
dwi
회원 가입일: 07/02/13
163 평판
안내서 1개 작성함
댓글 2개
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - 답글
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Brenda Kent - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 4,123
