주요 콘텐츠로 건너뛰기
Repairing Nokia Lumia 520 Power Button
필요한 것
  1. Repairing Nokia Lumia 520 Power Button, Repairing Nokia Lumia 520 Power Button: 1 단계, 이미지 1/1
    • Remove the back cover from the phone.
    • Take a bus ticket or anything else that has a thickness of 0.5-0.6 mm.
    • Cut the ticket to form a triangle.
    • Insert the triangle in the gap between the button and the chassis.
    • Cut the part of the ticket that is out of the chassis.
    • Now with a paper clip tests if it works.
    • If it works remount the back cover. If i doesn't work probably the problem is the button and not the contact and you need to replace it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
keroro90
회원 가입일: 08/07/14
213 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,848
