주요 콘텐츠로 건너뛰기
Repairing Oster 6344 Toaster Lever
필요한 것
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: 1 단계, 이미지 1/3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: 1 단계, 이미지 2/3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: 1 단계, 이미지 3/3
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: 2 단계, 이미지 1/2 Repairing Oster 6344 Toaster Lever: 2 단계, 이미지 2/2
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: 5 단계, 이미지 1/1
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
결론
Daniel
회원 가입일: 07/13/13
109 평판
안내서 1개 작성함
UC Santa Barbara, Team 2-6, Bradley Spring 2013 UC Santa Barbara, Team 2-6, Bradley Spring 2013 회원
UCSB-BRADLEY-S13S2G6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 1,628
