이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Switch off the unit and remove the top cover of the Oxycom. There will be 6 screws; remove them.
Cut two sides of the plastic cover with a sharp knife. Collect all sprinklers through that hole.
Apply one drop of Super Glue to the side of the "pipe" on the sprinkler and reinstall it into the white plug by pressing it in. Do the same to all of the loose sprinklers.
There are metal "supports" located inside as well. Put them back in any chosen place. No need to put them under the sprinklers because there are additional round places for them.
Use silicone to seal the plastic. Use duct tape over silicone to ensure that the plastic will be kept in the proper position. Leave that tape inside.
Replace the cover.
Mix 100g of powdered citric acid with 4 liters of warm water.
Pour the solution into the water reservoir.
Start the unit, set it to max cooling and max speed.
After setting to max speed and max cooling press ON/OFF and COOL buttons quickly at the same time and hold for 5 seconds until a beep is heard.
Let the unit run for 1 hour. Then turn it off and drain the solution from reservoir.
다른 3명이 해당 안내서를 완성하였습니다.
