소개
Sometimes during printing the paper will become jammed inside the printer. There are three places in which paper can become jammed. The following guide shows you the three different ways of removing the jammed paper depending on where the jam occurs.
Press the front cover release button.
Keep the button pressed and pull the cover toward yourself.
If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
Proceed to lift paper up and out of the printer.
Jammed paper may require an excess amount of force to be removed from printer.
Grab onto the lift located on the paper tray near the bottom on the front of the printer.
Pull the paper tray completely out of the printer by pulling towards yourself.
Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
다른 2명이 해당 안내서를 완성하였습니다.
