주요 콘텐츠로 건너뛰기
Repairing Polaroid Sun 600 LMS Gear Train
필요한 것
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 1 단계, 이미지 1/2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 1 단계, 이미지 2/2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: 2 단계, 이미지 1/1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: 3 단계, 이미지 1/1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Matthew Lessig
회원 가입일: 01/20/10
63 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010 회원
CPSU-MANESS-W10S3G18
4 회원들
안내서 4개 작성하였습니다
댓글 3개
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - 답글
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 32
전체 시간: 9,046
