이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
How to manually advance a stuck gear train.
필요한 것
Move film door slide on the left side of camera forward.
Pull film door open.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
