주요 콘텐츠로 건너뛰기
Repairing Puppet Strings
필요한 것
  1. Repairing Puppet Strings, Repairing Puppet Strings: 1 단계, 이미지 1/1
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
  2. Repairing Puppet Strings: 2 단계, 이미지 1/1
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
  3. Repairing Puppet Strings: 3 단계, 이미지 1/1
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
  4. Repairing Puppet Strings: 4 단계, 이미지 1/2 Repairing Puppet Strings: 4 단계, 이미지 2/2
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
  5. Repairing Puppet Strings: 5 단계, 이미지 1/1
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
  6. Repairing Puppet Strings: 6 단계, 이미지 1/1
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
  7. Repairing Puppet Strings: 7 단계, 이미지 1/1
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
  8. Repairing Puppet Strings: 8 단계, 이미지 1/1
    • This is what your puppet should look like.
    • Happy puppet-ing!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephanie Gummelt
회원 가입일: 10/27/15
155 평판
안내서 1개 작성함
Missouri Western, Team 1-4, Adkins Fall 2015 Missouri Western, Team 1-4, Adkins Fall 2015 회원
MWSU-ADKINS-F15S1G4
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 23
전체 시간: 3,034
