주요 콘텐츠로 건너뛰기
Repairing Quasar Microwave Fan
필요한 것
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1개 중 1개
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: 2 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Fan: 2 단계, 이미지 2개 중 2개
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: 3 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Fan: 3 단계, 이미지 2개 중 2개
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: 4 단계, 이미지 3개 중 1개 Repairing Quasar Microwave Fan: 4 단계, 이미지 3개 중 2개 Repairing Quasar Microwave Fan: 4 단계, 이미지 3개 중 3개
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 5 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 5 단계, 이미지 2개 중 2개
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: 6 단계, 이미지 1개 중 1개
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Melanie
회원 가입일: 09/26/12
107 평판
안내서 2개를 작성함
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 7
지난 30일: 13
전체 시간: 1,589
