주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Repairing Quasar Microwave Fan
필요한 것
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1/1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: 2 단계, 이미지 1/2 Repairing Quasar Microwave Fan: 2 단계, 이미지 2/2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: 3 단계, 이미지 1/2 Repairing Quasar Microwave Fan: 3 단계, 이미지 2/2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: 4 단계, 이미지 1/3 Repairing Quasar Microwave Fan: 4 단계, 이미지 2/3 Repairing Quasar Microwave Fan: 4 단계, 이미지 3/3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 5 단계, 이미지 1/2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: 5 단계, 이미지 2/2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: 6 단계, 이미지 1/1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Melanie
회원 가입일: 09/26/12
107 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,500
