이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the eight screws holding the wood-patterned cover to the microwave frame.
The first four screws are located on either side of the microwave front.
Remove the additional four screws securing the wood-paneled case to the microwave frame.
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
Lift the case upward slowly until the case is free of the microwave.
Locate the fan in the newly exposed interior.
Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
If the fan does not spin freely, locate what is jamming the fan and remove it.
If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
다른 한 분이 해당 안내서를 완성하였습니다.
