주요 콘텐츠로 건너뛰기
Repairing Rattling Sensor in Logitech G303 Computer Mouse
필요한 것
  1. Repairing Rattling Sensor in Logitech G303 Computer Mouse, Repairing Rattling Sensor in Logitech G303 Computer Mouse: 1 단계, 이미지 2개 중 1개 Repairing Rattling Sensor in Logitech G303 Computer Mouse, Repairing Rattling Sensor in Logitech G303 Computer Mouse: 1 단계, 이미지 2개 중 2개
    • Pry off the mouse feet located at the front and back of the underside of the mouse by wedging a flat head screw driver into the depressed groove and applying upward force.
    • Ensure that the mouse is not plugged into any power source before starting the repair.
    • Carefully remove the feet and be wary of the adhesive. Careful handling will allow them to be reattached and not require the purchase of a new set of mouse feet
  2. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 2 단계, 이미지 3개 중 1개 Repairing Rattling Sensor in Logitech G303 Computer Mouse: 2 단계, 이미지 3개 중 2개 Repairing Rattling Sensor in Logitech G303 Computer Mouse: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, unscrew the three screws that hold the top and bottom halves of the mouse together.
  3. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 3 단계, 이미지 2개 중 1개 Repairing Rattling Sensor in Logitech G303 Computer Mouse: 3 단계, 이미지 2개 중 2개
    • Grip the mouse cable with one had and the top buttons with the other and apply force in opposite directions to separate the two halves of the mouse.
    • Try lightly squeezing the top buttons together while separating the two halves of the mouse.
  4. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 4 단계, 이미지 2개 중 1개 Repairing Rattling Sensor in Logitech G303 Computer Mouse: 4 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, unscrew the three internal screws.
  5. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 5 단계, 이미지 1개 중 1개
    • Remove the internal operating board by lifting it out of the bottom half of the mouse.
    • Handle the internals carefully to prevent damage from occurring.
  6. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 6 단계, 이미지 2개 중 1개 Repairing Rattling Sensor in Logitech G303 Computer Mouse: 6 단계, 이미지 2개 중 2개
    • First Adhesive Method:
    • Apply a thin bead of the Silicon caulk to the rim of the sensor component.
    • Ensure that no Silicon is covering the center where the sensor is located.
    • The Silicon takes 30 minutes to set. This allows slight adjustments to be made if the Silicon initially covers the sensor.
  7. Repairing Rattling Sensor in Logitech G303 Computer Mouse: 7 단계, 이미지 1개 중 1개
    • Second Adhesive Method:
    • Attach the double sided tape to the bottom half of the housing. Place them directly over the central grooves.
    • Ensure that the central hole is not covered so the sensor still functions as designed.
결론
To reassemble your device, follow these instructions in reverse order. Lastly, ensure that none of the adhesive is blocking the sensor on the bottom of the device.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Benjamen Zielinski
회원 가입일: 06/20/18
215 평판
안내서 1개를 작성함
Washington State, Team S1-G4, Hope Summer 2018 Washington State, Team S1-G4, Hope Summer 2018 회원
WSU-HOPE-SU18S1G4
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 39
전체 시간: 3,988
