부품
  1. Before disassembly, make sure that the device is unplugged.
    • Before disassembly, make sure that the device is unplugged.
    • Unscrew the two 17.83 mm black screws located on the handle.
  2. Separate the shell from the main component.
    • Separate the shell from the main component.
    • Make sure that the each piece is free from debris.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Continue to pull the components apart. For reassembly, put the silver encasing on before the the black cover. For reassembly, put the silver encasing on before the the black cover.
    • Continue to pull the components apart.
    • For reassembly, put the silver encasing on before the the black cover.
  5. Locate the switches in the handle of the device.
    • Locate the switches in the handle of the device.
  6. Set the multimeter to 200 ACV.
    • Set the multimeter to 200 ACV.
  7. Bring the probes toward each switch to test for continuity.
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a finite number, the circuit is open and the switch needs to be replaced.
    • To replace faulty switch, cut the wires and solder the wires back on to the new switch.
결론
Jessica Leyva
회원 가입일: 2012년 09월 18일
107 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 891
